ZigBee in the Sky
By World Scientific | August 26, 2014
This image depicts VELOX-I before and after deployment and a picosatellite. (Shuanglong Xie, Guo Xiong Lee, Kay-Soon Low, Erry Gunawan, 2014)
Small but mighty: Singaporean university’s miniature satellites take wireless sensor networks into space
26 August 2014 – A team of engineers from Singapore has successfully piloted the world’s first ZigBee wireless sensor network (WSN) for satellite communications.
With the weight of payloads being a major constraint in satellite design, constructing a lightweight, low power-consuming, wireless communication system to do away with cabling inside the satellite has always been a challenge for system designers.
The engineering team at the Satellite Research Centre of Nanyang Technological University in Singapore launched VELOX-I, which consists of a nanosatellite weighing 3.5 kg and a piggyback picosatellite weighing 1.5 kg, from the two highest points on campus. Designed to test the hypothesis that ZigBee, a cheap but powerful land-based wireless system, will perform equally well in space, both miniature satellites were configured with a ZigBee wireless network and equipped with small sensor nodes. These nodes perform functions such as local sensing, distributed computing and data-gathering within the satellite to support intra-satellite communications.
The satellites were found to be able to maintain inter-satellite communications with each other over remarkably long distances.
This experiment marks a breakthrough in aeronautical engineering, having been designed to evaluate the performance of WSNs in space. After conducting Received Signal Strength Indicator tests on the satellites’ radio frequency modules, a maximum range of 1 km was found to be achievable for inter-satellite communication in the campus environment. An even longer communication range can be expected in free space, due to the absence of signal attenuation caused by fading and diffraction.
To estimate the range of inter-satellite communication in free space, the team applied a link budget analysis based on the Friis transmission equation, deriving an average theoretical distance of 4.186 km and a maximum of 15.552 km. Published in the special issue of Unmanned Systems, these findings present a compelling case for further studies into inter-satellite communication systems with more complex designs.
The team also found that by replacing internally wired connections with wireless links, a satellite’s mass could be reduced by as much as 10%. With the twin pressures of minimizing development costs and maximising risk diversification imposing major constraints on satellite design, the production of comprehensive yet lightweight systems could benefit significantly from WSNs.
Although WSNs have been used in a wide range of applications in recent years, their use in space applications has, until now, remained limited. The Singaporean team’s data-driven survey has established a sound platform for future formation-flying satellite missions, and seems poised to create subsequent revolutions in space.
Their report appears in Unmanned Systems’ special issue on wireless sensor networks and applications.
For more information, visit www.worldscientific.com.
Machine Learning for Sensors
Going small with 3D printing
