Zinc Die-Cast Adjustable Levers with Push Button from J.W. Winco
By Laura Carrabine | August 12, 2011
J.W. Winco, Inc. announced it now offers series GN 303.1 Zinc Die-Cast Adjustable Levers with Push Button, Tapped Type, with Stainless Steel Components, available in inch and metric sizes.
These adjustable levers have proven to be ideal wherever parts have to be clamped in a confined space or in a particular lever position. The insert is connected to the lever via serrations which can be easily be disengaged. Pulling the lever upwards disengages the serrations, allowing it to be swiveled to the ideal clamping position. When the lever is released, the serrations automatically re-engage. The releasing button is an ergonomic design element and allows for effortless release action. However, this design is limited to applications that do not require the lever to be disassembled.
The handle is zinc die-cast, and the push button is nylon plastic. The insert and spring, as well as the screw for the push button, are stainless steel, European Standard No. 1.4305 (American Standard Series 303). The handle is available in matte black pebble finish electrostatically applied powder coat, smooth finishes in orange, gray, silver, or red textured finish, chrome plated or uncoated. The button is available in black, orange or gray; upon request, any color button can be combined with any color lever.
Special bores and threads are available upon request. For certain minimum quantities, special colors are also available upon request. A version with steel components, series GN 303, is also offered.
JW-Winco-Zinc-Die-Cast-Adjustable-Levers
J.W. Winco
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
