Zortrax introduces Endureal industrial 3D printer
By Leslie Langnau | September 25, 2019
Zortrax, a developer of 3D printers, launched the Zortrax Endureal at the TCT Show 2019 in Birmingham. This 3rd generation 3D printer is for industry and production lines. It has a large working field, dual-extrusion technology, an enclosed heated printing chamber and features that control the print quality and security.
The new device combines high efficiency, print security and features of the 3rd generation industrial printers with a large working field. It is designed for engineering and medical applications. With an efficient volume of 36 liters, the device measures 30 x 40 x 30 cm.
Working using LPD Plus technology, it can print in dual and single extrusion mode. The Endureal’s build plate is made of ferritic stainless steel covered with PEI film, so that all supported filaments adhere properly and models are easy to remove, even large and uniquely shaped ones.
The printer provides thermal management. In the Zortrax Endureal LPD Plus 3D printer, filament temperature is tightly controlled at each stage to achieve precision and the best mechanical properties of 3D printed parts. Filaments are stored in a closed temperature – and humidity controlled compartment. The user sets the temperature in the heated printing chamber. With its high-temperature hotend, the advanced extruder is ready to support high-performance polymers. The thermally shielded extruder compartment is always kept at the right temperature, avoiding interruptions in filament transmission.
The filaments supported by the printer include PEEK, with properties that include high wear resistance, excellent thermal properties, proven biocompatibility, good strength-to-weight ratio and high radiation resistance. These features are desired in sectors such as medicine, aerospace, automotive and mechanical engineering – wherever the highest print standards are key.
Perfect printing is only possible with print security. The Zortrax Endureal has 17 built-in sensors, which work in real time to guarantee seamless operation in high-tech manufacturing and product development projects. Printing can be monitored remotely using a camera installed in the printing chamber. Designed to work at high temperatures, the camera can stream live video. If a power outage is detected, the Blackout Response System uses energy stored in built-in capacitors to save the exact position of the printing head.
Once the power is back on, printing can resume from the same spot. Separate sensors work constantly to detect problems, such as a jammed or depleted filament. The printer also monitors filament spools’ weight to check whether there is enough material to complete the model. The temperature and humidity in the filament compartment is measured and controlled at all times, crucial during long 3D printing projects with highly hydrophilic materials like nylon, which absorbs ambient moisture.
The Endureal is as user-friendly as Zortrax’s desktop-class 3D devices. With its intuitive user interface and software prepared for each dedicated filament, the Endureal is ready to operate at full capacity from day one. It has Wi-Fi and Ethernet.  The Zortrax Endureal, the company’s third-generation industrial 3D printer, will be available from early 2020.
Zortrax
www.zortrax.com
Filed Under: 3D printing • additive manufacturing • stereolithography, Capacitors
Tagged With: zortrax
PCB mills
September 2020 Special Edition: 2020 Additive Manufacturing Handbook
The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
Top 3 reasons why you should consider additive manufacturing today for production parts
