Designed with easily-accessible carriage lubrication port, the cylinder is prelubricated at the factory for kilometers of maintenance-free travel. Stainless steel body and “U” cup seals provide lower dynamic friction and special rare earth magnet configuration enables the cylinder to deliver high magnetic coupling strengths.
Featuring a leak-free construction, the lightweight cylinder also comes with internally lubricated piston seals for longer service life and optional bumpers to minimize noise. Available in two models, the cylinder’s life can be significantly lengthened by adding lubrication through direct introduction of oil or air line mist lubricator every 160 linear km of travel. The company also offers other types of prelubrication.
Meanwhile, the load carrying capabilities of Bimba Ultran Slide rodless cylinder can be enhanced by external shock absorbers. If used properly, the shock absorbers can also improve the service life of the cylinder.
Pneumatic Tips
Bimba Ultran Rodless Cylinders support high loads
Pneumatic Tips
