Engineering Calculators
LinkedInTumblrStumbleUponReddit
A – S – Y – Z Parameter Conversion Calculator
Air Core Inductor Inductance Calculator
Battery Life Calculator
Bishop-Wisecarver Widget
Butterworth Pi LC High Pass Filter Calculator
Butterworth Pi LC Low Pass Filter Calculator
Butterworth Tee LC High Pass Filter Calculator
Butterworth Tee LC Low Pass Filter Calculator
Calculate Inductance of Electrode or Straight Wire
Capacitance-Frequency-Inductance Calculator
Capacitor Energy and Time Constant Calculator
Capacitor Parallel Plate Capacitance Calculator
Chebyshev Pi LC High Pass Filter Calculator
Chebyshev Pi LC Low Pass Filter Calculator
Chebyshev Tee LC High Pass Filter Calculator
Chebyshev Tee LC Low Pass Filter Calculator
Convert Units of Mass, Length, and Area
Convert Units of Pressure
Convert Units of Temperature
Decibel Calculators
Design World Conversion Calculator
Efficiency Bandwidth Product Calculators
Electrical Basics Calculator
Environmental Calculator Basics
Equal Component Butterworth High Pass Filter Calculator
Equal Component Butterworth Low Pass Filter Calculator
Flyback Transformer Power Supply Calculator
Frequency and Wavelength Calculator
Friis Path Loss Calculator
Heat Sink Temperature Calculator
Helical Antenna Calculator
HF Filter Calculator
Hydraulics Basics Calculator
IC 555 Timer Calculator
Inverting Operational Amplifier Resistor Calculator
L-C Resonance Calculator
Laser Real-Time Unit Converter
LED Resistor Calculator
Line Of Sight Calculator
Maximum Flux Density Calculator
Microstrip Inductor Calculator
MSP430 UART Register Calculator
Non-Inverting Operational Amplifier Resistor Calculator
Ohm’s Law Calculator
Parallel Resistor Calculator
PCB Trace Width Calculator
Pi Attenuator Calculator
Pinhole Sizing Calculator
Pneumatic or Electric?
Polyester Capacitor Color Code Calculator
Pressure Conversion Calculator
Radar Range Calculator
Reactance Calculators
Resistance Frequency Capacitance Calculator
Resistor Color Code Calculator
RF Amplifier Calculator
RF Power Density Calculator
RMS Calculator
Sallen-Key Butterworth High Pass Filter Calculator
Sallen-Key Butterworth Low Pass Filter Calculator
Single Layer Coil Calculator
Skin Effect Calculator
Speed – Distance – Time Calculator
Standard Resistor Closest Value
Step Motor Basics
Subwoofer Box Enclosure Tuning Frequency Calculators
Subwoofer Vent Length Calculators
Subwoofer Vent Minimum Port Diameter Calculators
Tee Attenuator Calculator
Thermodynamic Basics
Velocity of Sound Calculator
Vented Ported Subwoofer Box Calculators
Voltage Current Resistance Power Calculator
Voltage Divider Calculator
Voltage Drop Calculator
Volume Basics Widget Calculator
Wheatstone Bridge Calculator
Whip Antenna Calculator
Wire Parameter Calculator
Zener Diode Calculator
