Integrated servomotor and drive from Tolomatic now with PROFINET
 The ACSI integrated servo/motor/controller from Tolomatic is now available with PROFINET Industrial Ethernet protocol, allowing engineers to design easy-to-use and cost-effective electric actuator solutions for single-axis applications. The integrated package is suitable for replacing pneumatic cylinders and automating any simple axis of motion with Siemens or other PROFINET enabled PLCs.
With built-in configurations for Tolomatic electric actuators, the ACSI integrated controller automatically configures the motor, actuator, safety limits and other key settings inside the controller for quick and seamless integration. The PROFINET protocol is in addition to Tolomatic’s existing EtherNet/IP and Modbus-TCP options for the ACSI.
PROFINET is the standard for industrial networking in automation. It connects devices, systems and cells, facilitating faster, safer, less costly and higher quality manufacturing. It easily integrates existing systems and equipment while bringing the richness of Ethernet down to the factory floor, according to the organization’s website.
servomotor
As an integrated servomotor and drive, the ACSI creates a space-saving design. The integrated package does not require space in a control cabinet, making it ideal for machine retrofits and also for displacing pneumatic cylinder applications. Available in both linear setup and rotary setup, the ACSI is easily configured to the desired user units.
Certified by PI North America (PROFINET governing organization) to PROFINET v2.33 standards, the ACSI controller can be implemented on RT (Real Time) networks as an I/O device. Available GSDML file and an archive of data blocks and function blocks for use with the latest Siemens PLC’s eases setup and allows for ultra-fast deployment into PROFINET control systems.
Available in two sizes (NEMA 23 and 34), with peak torques up to 1.35 Nm (12 in-lb), the ACSI features standard M12 connectors, an IP65 rating, dual Ethernet ports with LED indicators for easy troubleshooting and a USB microprogramming port. All models of ACSI come equipped with 24 Vdc digital I/O (4 inputs/2 outputs) and 0-10 Vdc / 4-20 ma analog I/O (1 input/1 output) for distributed sensors and logic to expand the network. The dual Ethernet ports with integrated managed switch allow many axes to be daisy-chained without affecting network performance.
Tolomatic will mount the ACSI to the actuator of choice, configure it, test it and ship it to the customer under one part number, saving time with purchasing multiple part numbers and also creating one point of responsibility for application support.
For more information, visit www.tolomatic.com.
Speak Your Mind
