National Bronze Mfg. Co., announces the addition of “M Series” enduralube bearings to their vast product lines of copper alloy based products.
Enduralube self-lubricating are known as some of the most reliable bronze bearings in the market. This reliability comes from the combination of the cast bronze base metal and the proprietary solid lubricant plugs. This combination gives our customers a maintenance free bearing able to withstand even the most extreme environments.
One of the many advantages of using a bronze alloys as a base metal is the ability to match specific bronze alloys with applications that will benefit from the advantages of the bronze alloy. The enduralube “M Series” bearings utilize a manganese bronze as the base metal. These bearings can be used in applications that require higher than normal load bearing capabilities with a slower rate of motion. The high strength manganese bronze provides the added strength need for these applications, and the solid lubricant plugs provided the necessary lubrication to keep the bearings moving.
http://www.nationalbronze.com
The post Introducing enduralube “M Series” bearings appeared first on Bearing Tips.
Filed Under: Bearings, Bearing Tips
