Piab has two product options for the piCOMPACT range. The first is an industry-standard M8 6-pin connection option. This threaded connection allows more pull force on the connection. This is suitable for moving and vibrating applications, such as robotic applications. The second option is an air valve with “clean room” housing. The unit can manage higher cleanroom requirements (higher ISO class) and can be used in rooms that have ISO 14644 standards.
Ejectors in the piCOMPACT range are smaller and lighter than conventional ejectors, reducing the total weight of vacuum handling systems.
The piCOMPACT vacuum ejectors fit with a variety of systems, including those that require very low feed pressure and deep vacuum levels. In addition, the compact ejectors can be easily integrated into existing production lines with no modifications required, and can be quickly configured to meet individual manufacturing needs.
Piab
Filed Under: Valves, Pneumatic Tips
