Boston Gear has launched a line of stainless steel mounted bearings and shaft couplings designed for high pressure food processing and packaging washdown applications.
The line includes pillow block and flanged mounted bearings featuring cast stainless steel housings, synthetic lip seals and NSF H1 food grade grease. SSFC Series, insert (3-jaw) type shaft couplings made of 316 stainless steel with passivated finish are also offered with a choice of oil-impregnated Bost-Bronz, oil-resistant synthetic rubber or polyurethane inserts. Units require no lubrication and are available with precision machined bores or solid hubs. Custom bore sizes are also available.
Boston Gear
The post Stainless steel mounted bearings and shaft couplings for washdown applications appeared first on Bearing Tips.
Filed Under: Bearings
