The ultra-miniature Beswick M3 threadeddry-break quick disconnect is manufactured from corrosion resistant stainless steel and is rated to 500 psig when connected. Buna-N is the standard seal material. Viton and EPDM are optional and can handle many types of fluids.
The dry-break, or “no-spill” , configuration is a more sophisticated version of a standard double shut-off quick disconnect. The advanced dry-break design ensures that there is essentially no leakage during connection or disconnection. It also minimizes the dead volume between the internal and external ends.
The ultra-miniature Beswick M3 threaded dry-break also comes in larger models in dry-break, double shut-off, single shut-off and no shut-off styles.
Beswick
www.beswick.com
Filed Under: Valves, Pneumatic Tips
