These heavy-duty, zinc free, extreme pressure, 100% synthetic based fluids are designed for applications where an extreme pressure synthetic fluid is required.
They deliver extreme pressure protection, have anti-wear properties and very low coefficients of friction, resulting in lower operating temperatures, reduced power consumption and longer equipment life.
Thermal stability and oxidation resistance increases service life, providing extended drain intervals. Compatible with a broad range of seals.
Lubriplate
www.lubriplate.com
The post Heavy-duty, extreme pressure, lubrication for bearings appeared first on Bearing Tips.
Filed Under: Bearings, Bearing Tips
