A new test setup is billed as being the most accurate way of characterizing and debugging IEEE 802.11ad transmitter PHY. Developed by Tektronix, the equipment is based on the 70 GHz DPO70000SX Series ATI Oscilloscope powered by SignalVu Option SV30. It is said to deliver industry best residual error vector magnitude (EVM) measurements along with easy setup for characterization and debugging capabilities.
Promoted by the Wi-Fi Alliance, IEEE 802.11ad or WiGig is aimed at providing data throughput speeds of up to 7 Gb/sec. To hit these speeds over short distances, the 802.11ad PHY layer uses frequencies in the unlicensed 60 GHz spectrum band. The high frequencies involved – up to 65.80 GHz in some markets – have presented a number of test and measurement challenges, including the need for multiple instruments that must be calibrated together and difficult cross-domain debugging due to the frequencies involved.
“With this new solution, we are removing major obstacles to 802.11ad validation, by providing a single-box solution that spans the entire 60-65GHz spectrum; which simplifies test setup and debug, giving our customers a time-to-market advantage,” said Brian Reich, general manager, Performance Oscilloscopes, Tektronix. “The level of performance we’re able to achieve with our low-noise 70 GHz oscilloscope is already being well received by wireless development teams who are currently working to bring 802.11ad silicon to market.”
Taking advantage of the DPO70000SX oscilloscope’s low-noise ATI acquisition technology, characterization can take place with an EVM that is specified at 2.5% (-32.0 dB). Competitive offerings require down-conversion and the need for two instruments to be calibrated; degrading accuracy and lengthing set-up time.
The Tektronix 802.11ad solution speeds debugging by providing cross correlation between RF and time domains for deeper insight into potential problems. Tektronix says its equipment also supports live triggering on signals up to 70 GHz, compared to just 63 GHz (below the 65.80 GHz required in some markets) for the nearest competitor’s offering. For greater measurement precision, Tektronix complete 802.11ad transmitter test solution also includes capability to de-embed cables, attenuators or amplifiers in front of the scope with SDLA64.
70GHz DPO70000SX Series ATI Oscilloscopes and SignalVu (option SVE) software are available now. The SV30 option for 802.11ad testing is priced at $9,000 US MSRP.
The post IEEE802.11ad test gear handles EVM
measurements out to 70 GHz appeared first on Test & Measurement Tips.
