Interpower is pleased to announce it has added to its IEC 60320 inlet product line as it is now manufacturing in its Iowa facility its own C14, C16, and C18 snap-in inlets designed for 2.0 and 3.0-mm panel thicknesses.
All of these snap-in inlets are rated 10 A/250 Vac international and 15 A/250 Vac North American, have QD and solder tab options, and fit a 20 x 27.5-mm cutout. They carry VDE and cURus approvals and are RoHS compliant.
The Interpower C14 snap-in inlet is now available in 1.0, 1.5, 2.0, and 3.0-mm panel thickness. It is rated up to 70°C and can be used in an application that requires connection to a C13 connector.
The Interpower C16 snap-in inlet is now available in 1.0, 1.5, 2.0, and 3.0-mm panel thickness. It is rated for “hot” conditions (up to 120°C) and can be used in an application that requires connection to a C15 connector.
The Interpower C18 snap-in inlet is now available in 1.0, 1.5, 2.0, and 3.0-mm panel thickness. It is rated up to 70°C and can be used in an application that does not require a provision for grounding and requires a connection to a C17 connector.
Interpower
www.interpower.com
Filed Under: Uncategorized
