LED dimming control module handles 10 A
phihongPhihong has introduced a new 10A, touch-operated dimming control module for constant voltage indoor LED lighting applications, such as under cabinet lighting and architectural accent lighting. Designed to integrate into both new and existing LED applications, the new PDA-DIM10A touch dimming control module is rated for constant voltage input spanning 8V – 42V, and features an on-board touch sensor and a 200-step dimming resolution. The new wall-mounted touch module also features tap on/tap off and touch-and-hold dimming controls, which allow users to turn the module on and off and adjust dimming with ease.
The PDA-DIM10A measures 68mm x 35mm x 20mm (2.68” x 1.38” x 0.79”) and weighs 30g (1.06oz). Operating temperatures for the series span -20˚C to +40˚C. Pricing for single-unit quantities starts at $29.84.
Phihong
phihong.com
Power Electronic Tips
