Parker’s Duramax low-temperature hoses offer flexibility in operating environments with low temperatures. With a 3,000 psi constant working pressure, the hose is designed to withstand and perform in cold or refrigerated areas, such as construction or agricultural equipment in cold climates.
The matte cover creates a low coefficient of friction while the hose has a better bend radius than SAE J517 and 100R18. The tube of the hose is made of copolyester and has fiber reinforcement. The working and burst pressures are rated at 73° F (23° C).
The Duramax uses 55 Series, 56 Series, 58 Series, 58H Series and HY Series fittings.
Parker
parker.com
The post Low-temperature hydraulic hose flexible in cold climates appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
