This webinar was recorded on Tuesday, July 19, 2016.
Watch the on demand webinar.
Most engineers are familiar with traditional wire wound (coiled) springs, but in this webinar attendees will learn about a viable alternative known as “machined springs”. Based on the whitepaper “Choosing between Machined and Wire Wound Springs”, the webinar will review differences between these two types of springs along with the advantages of both.
If you work with torsion or compression/extension springs learn why a spring with a Pure Moment and Resolved Moment can significantly improve your products performance. The subject of preventing rotation when a spring compresses or extends will also be covered. Engineers will hear spring design options that will simplify and benefit their design efforts.
Attend this webinar to learn:
- Comparison between machined springs and wire wound springs
- Adding value by integrating other components to make a single spring solution
- Differences and limitations in spring coil geometry
- Achieve excellent squareness under load
- Adding redundancy into spring designs
Featured Speakers
Alex Ek, Manufacturing & Engineering Manager, Helical Products Company
With his bachelors of Science degree in Mechanical Engineering and emphasis in Stress Analysis and Mechanical Vibrations, Alex Ek has over thirty years of practical experience in applied mechatronics and automatic machine design. As the Current Stress Analyst for Helical Products and with extensive experience in machine design, Alex brings a valuable mix of theoretical and practical knowledge to assist designers with new applications that can be enhanced by the HELI-CAL Machined Spring®.
Sponsored by:
Filed Under: WEBINARS
