Nippon Pulse’s PCL6000 series of chip-level controllers include the two-axis PCL6025B and the four-axis PCL6045BL and PCL6046 chips. Their advanced features have long made them the most advanced controller chips in the world. In addition to standard linear and circular interpolation options, two of the advanced controller chips now feature a third interpolation option — spiral or helical interpolation.
The PCL6045BL and PCL6046 four-axis chips can both execute spiral interpolation. For this type of movement, linear and circular motion profiles are used simultaneously, combining to create three dimensions of movement. The zero point keeps moving, and the X and Y axes synchronize with the Z axis for either clockwise or counter-clockwise helical motion.
Spiral interpolation can be used in conjunction with acceleration and deceleration as well … by entering the number of pulses required in the register for control axis. For more information about this feature and how to perform these operations, check out section 9.8.9 in either chip’s user manual: PCL6045BL and PCL6046 on the Nippon Pulse Manuals and Literature page.
Item | Description |
Available configurations | 2 or 4 axis |
Max output speed | PCL6025B/6045BL: 10 Mpps (with 20 MHz reference clock) PCL6046: 10 Mpps (with 30 MHz reference clock) |
Position Range per Axis | PCL6025B/6045BL: -134,217,728 to +134,217,727 (28-bit)
PCL6046: -2,147,483,648 to +2,147,483,647 (32-bit) |
Speed Range per Axis | 1 to 65,535 (16-bits) |
Acceleration Rate Range per Axis | 1 to 65,535 (16-bits) |
Deceleration Rate Range per Axis | 1 to 65,535 (16-bits) |
Mechanical sensor Input per Axis | ORG, +EL , -EL, SD |
Servomotor I/F per axis | INP, ERC, ALM servomotor inputs |
Encoder input max frequency | PCL6025B/6045BL: 1.7 MHz (with 20 MHz reference clock) PCL6046: 2.5 MHz (with 30 MHz reference clock) |
Typical operations |
• Continuous operation • Origin-return operation • Positioning operation • Timer operation • Continuous operation using a ±DR switch • Continuous operation using pulsar input |
Typical functions |
• Immediate stop and decelerating stop • Speed change • External start and external stop function • Idling pulse output function • Continuous circular and linear interpolation |
Registers for speed setting per axis | 3 (FL, FH, FA) |
CPU interface | 8-bit, 16-bit |
Power supply | PCL6025B: 3.0 to 3.6 V and 4.5 to 5.5 V
PCL6045BL/PCL6046: 3.0 to 3.6 V |
Package |
PCL6025B: 128-pin QFP (mold section :20.0× 14.0 mm) PCL6045BL: 176-pin QFP (mold section :24.0× 24.0 mm) PCL6046: 208-pin BGA (mold section :12.0× 12.0 mm) |
Chip design | CMOS (Complementary Metal-Oxide Semiconductor) |
Nippon Pulse America Inc. is an American subsidiary of Tokyo-based Nippon Pulse Motor Co., Ltd. Nippon Pulse is a global manufacturer and Tier 1 supplier of precision motion control products for original equipment manufacturers. We provide a wide array of motion control solutions to meet your needs, including industry-leading stepper motors, the innovative Linear Shaft Motor, controllers and drivers. For more information about Nippon Pulse’s quality products, visit nipponpulse.com.
Filed Under: Motors • stepper, Motion Control Tips
