Clippard’s 10 mm valve also has the capability to detach the connector and the coil from the valve body. This is useful when exchanging voltages or connector types, or when positioning the coil by 180 degrees.
The company has also fitted the valves with LED for confirmation of operation and diodes for current spike suppression.
To help users identify the valve, the company has color coded the top plate — silver plated valves are the Normally Closed version, while black plated valves are the Normally Open.
Pneumatic Tips
Clippard 10 mm miniature valves deliver up to 110 psig
Pneumatic Tips
