Guardian Couplings’ curved jaw flange coupling
Guardian JF K45 couplingGuardian Couplings has launched the new curved jaw flange (JF) K45 Series shaft-to-shaft coupling with a bolt-on disc for use with brake calipers. The new torsionally flexible coupling is designed for industrial applications including various types of cranes and hoists, winches, and mining conveyors, reclaimers and draglines.
Five models are available with bore sizes from 0.87 to 4.92-in. diameter and braking torque ratings from 8,310 to 63,720 in.lbs. The coupling’s brake disc and flexible spider element can be easily replaced during assembly. The brake disc must be mounted to the shaft end with the largest mass moment of inertia.
Guardian Couplings
guardiancouplings.com
Speak Your Mind
