For the small medical instrument needs, this compact HCDS-025-038-02-B1-01 Voice Coil Stage from Moticont has a foot print of 2.000 in. (54.0 mm) wide by 5.000 in (127.0 mm) long and features a positioning resolution of 1 micron and a 0.125 in. (3.175 mm) open aperture. This precision cross roller stage has a 0.97 in. (24.6 mm) range of motion with 1.0 lb. (4.4 N) of continuous force and 3.2 lb (14.2 N) peak force. The zero cogging, clean, quiet, efficient, low inertia, high acceleration, high speed voice coil driven stage has a built-in home switch for accurate initialization. As the coil is fixed and the magnetic assembly moves, there are no moving electrical components to fail. Designed for closed loop servo operation an integral quadrature optical encoder with differential outputs is included.
The stage table has 4 8-32UNC-28 mounting holes. Pre-drilled and counter-bored mounting holes in the base and a plug -and-play wired connector for easy integration into new or existing applications. This black anodized voice coil stage with a clear aperture suits applications in laser drilling, optical focusing, testing, laser steering, mirror positioning, scanning, oscillation, switching, applications in industrial, medical, metrology, and research fields.
The HCDS-025-038-02-B1-01, voice coil driven stage is available as part of an XY or XYZ stage.
Moticont
www.moticont.com
Filed Under: Motors (linear), Medical-device manufacture, Encoders • optical
