The LMP-0501 and LMP-0501-24 series is an expansion in the industrial PoE+ networking infrastructure family of Antaira Technologies.
The switches are a 5-port industrial PoE+ managed Ethernet switch, with 48-55 Vdc high voltage power input (LMP-0501) and 12-36 Vdc low voltage power input with a built-in voltage booster (LMP-0501-24). Each unit has four 10/100Tx Fast Ethernet ports that are IEEE 8023.at/af compliant (PoE+/PoE) with data and PoE up to a maximum power output of 30 W per port.
There is one additional 100Fx Fiber port that supports either an SC or ST type connection, and has either a multi-mode 2 Km or single-mode 30 Km option.
Each unit provides a high EFT, surge (2,000 Vdc) and ESD (6,000 Vdc) protection. Each unit also has a dual power input design and reverse polarity protection. A built-in relay warning function alerts maintainers when power failures occur.
This product series is pre-loaded with the “Layer 2” network management software. These managed switches provide the redundant networking ring function along with the Rapid Spanning Tree Protocol (RSTP) and the ITU-G.8032 support, which helps to eliminate the compatibility issue for an existing network. In addition, the units have built-in SNMP, VLAN, IGMP, QoS features that help support network planners to increase data transmission performance within the network. The external USB 2.0 port allows users to export and save all the configuration settings.
www.antaira.com
Filed Under: TECHNOLOGIES + PRODUCTS, Networks • connectivity • fieldbuses
