GGB Bearing Technology EXALIGN, MINI and UNI self-aligning bearing assemblies compensate for shaft misalignment up to +/- 5º, reducing edge-load, premature wear and power transfer deficiencies.
Highlights:
GGB self-aligning bearing assemblies work with a wide range of GGB plain bearings, simplify installation and increase application service life. GGB self-aligning bearing housings adjust to +/- 5 degrees. Bearing assemblies are available in universal, flange or plummer/pillow block configurations.
Available in a range of configurations to meet most bearing assembly needs, these housings are compatible with a wide range of GGB plain bearings, simplifying installation and increasing service life.
The self-aligning sphericals are secured against distortion, and combined with different housings and GGB bearings, provide optimal design solutions for a wide range of applications.
The product line includes standard ranges:
MINI self-aligning housings are available in universal, flange or plummer block configurations, and are made of aluminum alloy with steel sphere inner material. They can accommodate bearing inner diameters of 8 to 15 mm.
UNI self-aligning housings are available in universal, flange or plummer block configurations, and are made of ductile cast iron with a steel inner sphere material. They can accommodate bearings with inner diameters of 10 -100 mm.
EXALIGN self-aligning housings are available in plummer block, or two- or four-bolt flange configurations, with both the housing and inner sphere material consisting of cast iron. They can accommodate bearings with inner diameters of 10 -100 mm.
These housings will most frequently be used with GGB’s line of metal-polymer and fiber reinforced composite bearings in applications including:
Wind energy plants
Car washes
Cleaning machines
Drum systems
Beveling equipment
Handling systems
Conveyor belts (pulleys)
Printing machines
Heating and ventilation equipment
Hoists
Cranes
Textile machinery
Special machine engineering
Bakery equipment
Marine equipment
The post Self-aligning bearing assemblies reduce edge load, minimize misalignment appeared first on Bearing Tips.
Filed Under: Bearing Tips
