Making a sensor easy to replace in industrial applications should get the attention of many users. For sensing proximity, SICK’s IQG inductive proximity sensor targets a wide variety of applications.
For easy replacement aspect #1, the 40 x 40-mm sensor can fit into most brackets. For easy replacement aspect #2, the sensor’s tight manufacturing tolerances avoid the need to readjust the sensor during replacement. For easy replacement aspect #3, the sensor head can be rotated in 5 directions, allowing the sensor to easily be adapted to suit a wide range of applications. Four corner LEDs enable straightforward status monitoring, regardless of mounting position.
For more information, click here.
Filed Under: Sensor Tips, Flanges • supports • mounts • brackets
