    • On the Floor
AutomationDirect Offers Additional RFID Coded Non-contact Safety Switches
By Frank Tobe | December 14, 2016
SPF-M-AutomationDirectAutomationDirect has extended their offering of safety products to include the LPF and SPF-series RFID non-contact RFID coded safety switches. These non-contact safety switches use RFID communication between switch and actuator to provide the most tamper-proof protection using both master and unique coded actuators. When used in combination with a dual-channel safety relay, RFID-coded non-contact safety switches can be used to provide protection up to Category 4 and PLe to ISO13849-1.
The IP69K-rated LPF and SPF-series operate with most safety relays and feature plastic housings, wide sensing distances (>10mm), and a high tolerance to misalignment after sensing. With switching capability up to 0.2A, models are available in unique-coded and master-coded styles with 2m, 5m, or 10m pigtail cables or a 250mm quick-disconnect cable.
Female quick disconnect cables, in 5m and 10m lengths, and replacement master-coded actuators are also available.
AutomationDirect
www.automationdirect.com
Filed Under: INDUSTRIAL SAFETY SYSTEMS, MOTION CONTROL, Switches
Tagged With: automationdirect
  • Robot blowback in Korea and China growth slows
  • Robot safety in focus as regulations change
    • On the Floor
