    • Subscribe!
Capacitive incremental encoder line to supports shaft sizes up to 5/8 in
By Aimee Kalnoskas | September 13, 2019
AMT13 seriesCUI’s Motion Group announced the addition of a new series to its innovative AMT incremental encoder family to support larger motor shaft sizes from 9 mm to 15.875 mm (5/8 inch). The AMT13 series, based on CUI’s proprietary capacitive ASIC technology, brings the same high levels of durability, accuracy, and immunity to environmental particulates as current AMT encoder models. Ideally suited for a variety of robotics, industrial, and automation applications, the series offers 22 programmable resolutions from 48 to 4096 PPR, CMOS voltage or differential line driver outputs, and low current consumption of 16 mA at 5 V.
Available in radial or axial orientations, the AMT13 incremental encoder is housed in a compact 42.3 x 42.3 x 13.5 mm package and carries a wide -40 to +125°C operating temperature range. Its digital nature and compatibility with CUI’s AMT Viewpoint software makes the AMT13 encoder highly customizable with the ability to easily configure the resolution and set the zero position.
The AMT13-V kit affords users further flexibility in their design with the inclusion of 9 different sleeve bore options from 9 mm to 5/8 in and simple mounting tools to assist in the easy installation process onto a motor.
The AMT13 series is available immediately with prices starting at $29.49 per unit at 50 pieces through distribution.
Filed Under: Sensor Tips
Tagged With: cuimotiongroup
LPPS-36B Series Linear Potentiometer Position Sensor with Rod Ends
Hybrid sensors for connected vehicles
How are wearable systems improving?
Faster than any other IDS industrial camera: uEye Warp10 with 10GigE
    • Subscribe!
