    • Subscribe!
Centering Belts and Reject Paddle Featured in Process Line
By Frank Tobe | May 6, 2014
The manufacture of insulation rolls and batts is among the many diversified industries using LEWCO equipment. Recent units built for a customer serving this industry included conveyors for three process lines. Among the custom individual units were modular plastic belt conveyors, product reject paddles, and powered centering belts. A portion of one process line is shown below.
Lewco
Each product reject paddle was mounted overhead, and was designed to sweep 40 lb. products off the side of the main process line at a rate of up to 20 per minute. Special guide bearings were used to counter thrust loads and ensure long life. Additional area guarding was added by the end user during installation.
The powered centering belts were designed to eliminate the product drag and potential rotation that would occur on a static face guide rail. They ran at the same speed as the process line to gently center the product. The centering belts were mounted on pivots at the infeed end, allowing the exit opening to be manually adjustable to accommodate various product types.
Lewco
Above is one of the short wide modular plastic belt conveyors built for this customer.
Working with the customer throughout the design process ensured that expectations were met. You can rely on LEWCO, Inc. for all of your standard or custom conveyor needs.
LEWCO
www.lewcoinc.com
Filed Under: TECHNOLOGIES + PRODUCTS, Belts + chains, Conveyors
Tagged With: lewco
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
Ethernet remote I/O modules add Conditional Logic Computing
Self-contained actuator for a variety of applications
    • Subscribe!
