Custom high torque CD® couplings up to 20 in. in diameter handle 78,000 Nm peak torque. Available to system designers seeking robust couplings for large and challenging applications, these “super sized” couplings combine high torsional stiffness and high load capacity.
With torsional stiffness of 419,000 Nm/DEG and continuous torque of 39,000 Nm, these CD couplings have angular misalignment capacity of 1.5 degrees with axial misalignment of 6.5 mm and parallel misalignment of 0.24 mm.
Designed around the composite center disc, these couplings perform at these peak torques in hostile operating environments – from extreme cold to hot weather conditions -70° to +250°F (-57° to + 121°C). Time-proven applications include drive trains, gear boxes and generators in sea water and abrasive desert sand conditions.
The coupling’s composite center disc is manufactured to strict aerospace and Six Sigma practices. The hub material is 1045 HR steel with fasteners made of titanium 6AL4V grade 5 materials. All components are tested with Finite Element Analysis (FEA) software for predictable characteristics.
“The demand for super-sized CD couplings is growing rapidly, especially in different areas of the energy industry,” reports Kevin Wells, Zero-Max Regional Sales Manager. “We see this as an important new trend.”
Zero-Max
www.zero-max.com
Filed Under: Uncategorized
