The Sensor Connection a division of Harold G. Schaevitz Industries LLC, has expanded its line of temperature measurement and control instrumentation with the addition of the model DPG-SD-1 series digital Type K thermocouple temperature gauge. Manufactured in the USA, this microprocessor-based gauge is packaged in a compact 52mm O.D. round housing with an IP65 rated face ideal for use in harsh industrial environments. The bright red LED numeric display is easy to read, even at a distance. During a high temperature alarm condition the display flashes and an internal 2 Amp relay circuit is activated. Programming of the gauge is quick and easy using the front panel membrane keypad.
Features of the DPG-SD-1:
- Input: Type K Thermocouple sensor/li>
- Temperature units field selectable for °C or °F/li>
- User adjustable HI alarm set point/li>
- Max Peak Temperature recall function/li>
- Internal 2 Amp alarm relay circuit/li>
- IP65 rated face/li>
- Powered by 9 to 32 VDC/li>
- Display Range: +32 to +2282°F (0 to +1250°C)/li>
- Operating Temperature: -40 to +85°C/li>
- Case Size: 52mm O.D. x 38mm deep
Sensor Connection
www.sensorconnection.com
Filed Under: Sensor Tips
