Face recognition modules get 10X speed boost
By Lee Teschler | November 2, 2016
The Human Vision Components (HVC)-P2 module has a maximum recognition speed 10 times that of the previous model, which was introduced in March 2014. The HVC-P2 is offered in long-distance and wide-angle detection types and can be utilized in varying environments including homes, outdoors, and the workplace.
HVC-P2-The modules include a choice of wide-angle type and long-distance type lenses depending on detection distance and range needs. Horizontal angles of views can be from about 50 to 90° and vertical angles of view can be from approximately 40 to 70°. There are 10 OKAO Vision functions: body detection, face detection, hand detection, face direction estimation, gaze estimation, blink estimation, age estimation, gender estimation, expression estimation and face recognition. And the modules can easily be set up through USB or UART outputs.
The HVC-P2 module consists of a camera and separate main board, connected via a flexible flat cable (FFC). This allows installation on the edge of a flat display unit, which was previously difficult with all-in-one units. Output image communication can be chosen from three types: 320×240 pixels, 160×120 pixels and no image output.
TARGET APPLICATIONS:
Marketing, such as electronic signage
Register/POS
Building automation
Vending machines
Machine and robot operations
More info: https://plus-sensing.omron.com/product/B5T-007001/
Sensor Tips
Filed Under: Sensor Tips
Tagged With: humanvisioncomponents
Compact direct drive actuator boasts 1.25μm resolution
TMR magnetic sensors optimized for current, position sensing
Tiny dual-port pressure sensor simplifies design of PAP devices
AI/ML-based sensor fusion technology platform targets home-security alarm system
