Friday Bearing Fast FAQ 10:
By Mike Santora | January 1, 2016
Koyo-grease-imageWhen should grease be used for bearings?
Grease lubrication is generally restricted to relatively slower-speed applications due to reduced capability for frictional heat dissipation as compared with that of oil.
The advantages of grease over oil are 1.) It simplifies seal design, acts as a barrier to contamination and is a sealant. 2.) It permits pre-lubrication of sealed or shielded bearings, 3.) It generally requires less frequent lubrication, 4.) It has a simplified application system design and is less costly.
Koyo
www.jtekt-na.com
The post Friday Bearing Fast FAQ 10: appeared first on Bearing Tips.
Filed Under: Bearing Tips
Tagged With: koyo
  • Tech Toolbox: Designing for cleanrooms
