Extended series of spring-loaded LVDTs from NewTek Sensor Solutions provides accurate dimensional feedback for a variety of position measurement and quality assurance applications including go/no-go measurements, automotive part quality testing, roller position/product thickness control, TIR measurements and material testing under stress.
Designed with a stainless-steel probe assembly and ¾-in. diameter hermetically-sealed housing, these spring-loaded sensors operate in challenging environments with dirt, water, vibration and temperature ranges of –65° to 220°F while providing highly accurate position measurement with maximum linearity of +0.25% of full-scale output.
New Tek offers ac- and dc-operated versions of its gage heads in ranges from ±0.050 to ±2.00 in. (1.27 to 50 mm). With electronics built into a spring-loaded assembly, DC-operated units do not require external electronics, reducing installation time and costs. Ac-operated configurations can withstand higher temperatures and provide a variety of analog or digital outputs when connected to an LVDT signal conditioner such as NewTek’s NTC Qwik-CAL signal conditioner.
NewTek offers customized options for its spring-loaded LVDTs including extended temperature ranges up to 400°F (200°C), mild radiation resistance to 30 MRad, air extend probes and custom spring rates.
www.newteksensors.com
Filed Under: Sensor Tips
