Harold G. Schaevitz Industries LLC (HGSI) has expanded its sensor product offering by adding a line of ILPS-18S Series Spring Loaded Inductive Linear Position Sensors using LVIT Technology. The ILPS-18S was designed as an economical solution for dimensional gauging and position measurements in commercial, industrial, and military applications.
With their compact design, long service life, and excellent stroke-to-length ratio, ILPS-18S sensors are suitable for test stands, test laboratories, automated assembly machines, processing and packaging equipment, robotics, and automotive test applications.
ILPS-18S Features:
• Measuring ranges from 0.5 to 4 in. (13 to 100 mm)
• Excellent stroke-to-length ratio
• Lower cost replacement for spring loaded LVITs
• Long service life, rated to over 100 million cycles
• 0.75 in. (19 mm) diameter threaded aluminum housing sealed to IP-67
• Axial termination with either M12 connector or integral cable
The ILPS-18S series offer a choice of four analog outputs and all include HGSI’s proprietary SenSet™ field recalibration feature.
www.hgsind.com
Filed Under: Sensor Tips
