By using linear array technology, Banner Engineering’s LE550 non-contact laser sensor provides high repeatability and accurate measurement for a range of targets from shiny metal to black rubber. The laser diode sensors combine the alignment advantages of a visible sensing beam with the increased sensing range of a laser.
The LE550 sensor has a 100 mm to 1000 mm operating range. This capability provides a detection solution for measurement applications, including roll diameter, loop control, thickness measurement and positioning.
Enclosed in a rugged, die-cast zinc housing, the LE550 includes a polycarbonate lens cover rated to IP67.
For more information about the Banner Engineering LE550 Laser Sensor, click here.
Filed Under: Sensor Tips
