ColumbiaSoft launched Document Locator Version 5.3 Document Management System. It is Microsoft Windows 7 compatible, offers web access using .NET technology, and has enhanced integration with AutoCAD and Brava software packages.
Document management is integrated into the Explorer view and from right the click menu commands in Microsoft Windows including Windows 7.
The software is designed to work with both the 32-bit and the 64-bit versions of Microsoft Windows 7 and Windows Server 2008 R2. Integration with Microsoft operating systems and software, including Windows Explorer, Office applications, Outlook, and SharePoint, allow you to manage and share files from within other applications. This is supposed to simplify document management by making it easier for you to adopt document version control, records management, document imaging, email management, and other document management practices.
A new framework for the optional WebTools browser interface uses .NET and java scripting technology to improve web-based document management access. So, if you’re using the Web-browser, you could see faster performance and experience new design features that make the browser method similar to the Windows-based interface. For example, it’s now possible to import files by drag-and-drop in the Web-browser using a new file import process.
The new AutoCAD integration uses Autodesk’s RealDWG technology to speed the performance of CAD file management within the document management system. In addition, integrations with Brava! Enterprise and Brava! Desktop have been updated to support the most recent releases of the mark-up applications.
ColumbiaSoft
www.documentlocator.com
Filed Under: ENGINEERING SOFTWARE
