Maplesoft has been named an Encompass Product Partner in the Rockwell Automation PartnerNetwork Program. Through the partnership, joint customers of Rockwell automation and Maplesoft will benefit from technology that provides model-based tools for virtual commissioning. Using Maplesoft technology, customers can reduce integration problems through the development of high-fidelity, high-performance Digital Twins of their machines.
Integrating these Digital Twins with Studio 5000 from Rockwell Automation allows customers to predict dynamic loads on machine actuators, helping them to make better informed decisions on motor sizing, eliminate undesired dynamic effects, and maximize machine performance. It also helps customers reduce the costly integration problems typically associated with the first prototype of the machine, which reduces associated development costs. Model-driven Digital Twins, less expensive than traditional data-driven Digital Twins, assist in all stages of product design and are essential for virtual commissioning.
The capabilities provided by this partnership are based on MapleSim and associated professional services to ensure a rapid return on investment. MapleSim, the system-level simulation software from Maplesoft, is used across a variety of applications and industries. Because Digital Twins in MapleSim do not require test data to predict behavior, they can be used for conceptual design as well as to validate product performance, design changes, and diagnostics. Designers can test integration in a virtual commissioning phase, correcting issues that typically would not be discovered until after production.
“Too often, the first time machine manufacturers encounter problems with their design is during the hardware integration phases, when it is costly to address and risks disruption to the schedule,” said Paul Goossens, Vice President of Engineering Solutions at Maplesoft. “Building a digital twin of the machine within the Rockwell Automation platform – complete with mechanisms, motors, gearing and controllers – early in the process, allows customers to test the design through multiple duty cycles. This helps them to identify and address integration issues at a fraction of the cost of dealing with them in the later stages.”
Maplesoft
www.maplesoft.com
Filed Under: 3D CAD World
