Metric Incremental Encoder
By Design World Staff | April 22, 2007
Model M58 58 mm diameter industrial grade metric incremental encoder provides a range of options in a rugged industrial package. It comes with either a standard 10 or 6 mm shaft. The encoder has a wide range of resolutions, up to 80,000 cycles per turn. Built to industrial standards, it has excellent shock and vibration resistance. IP65 environmental protection level is standard or IP67 is available with sealing flange, making it suitable for dirty or wet environments commonly found in industrial applications.
BEI Industrial Encoders
www.beiied.com
Filed Under: Encoders (rotary) + resolvers
Tagged With: bei
POSITAL’s explosion-proof rotary encoders receive ATEX/IECEx certification
z4636-F5858-Profinet-enc-std-srgb-web
New generation industrial ethernet encoders from Kubler
Sendix M3658 encoder with IO-Link interface
Kubler- A41-product-shot
Kubler A41 draw-wire mechanism with encoder
