Westminster, CA — Noran Engineering, Inc. will demonstrate new software at the Association for Unmanned Vehicle Systems International Conference (AUVSI) in San Diego, CA June 10-12. NEi’s software portfolio allows engineers to virtually test air, land, and maritime vehicles and components for mechanical stress, deformation, vibration, thermal and other technical parameters at the design stage before prototypes or parts are fabricated. Engineering simulation benefits the overall design process by giving developers the tools to explore design alternatives, identify problems, optimize component function, and save time and resources in prototypes and test.
Screenshot of NEi Nastran Finite Element Analysis (FEA) software used to investigate distribution of stresses on an innovative aircraft platform of carbon composite using crossflow fans for thrust and flow in place of a conventional propeller. Courtesy of Propulsive Wing LLC and Allred & Associates. www.NEiNastran.com
Examples of new virtual test technology from NEi includes Automated Impact Analysis (AIA™), composite material modeling and Progressive Ply Failure Analysis (PPFA™), Automated Surface Contact Generation (ASCG™), and Design Optimization. AIA is used for a variety of impact scenarios from military projectiles to drop testing of electronics like cellphones and laptops. PPFA provides insight into composite damage mechanisms so engineers can get the maximum benefit from this class of material. Composites are a frequent material choice in unmanned systems because of their exceptional performance characteristics like high strength to weight ratio and stealth. ASCG makes realistic simulation of contact in assemblies practical and affordable because it eliminates the tedious time consuming aspects in this task. Design Optimization finds solutions to problems that have competing parameters, for example, structures that must be both strong and light.
NEi is at Booth # 135 and invites attendees with an interest in virtual test software to sign up prior to the show at www.NENastran.com/AUVSI2008 so material may be prepared that can address your specific application.
Filed Under: FEA software, Software
