The VP Series Performance Plus miniature spiral bevel gearboxes pack high performance in a small package with the highest torque density, range of ratios, and torque capacity on the market.
• Sizes 27, 33, and 45 mm
• Highest torque density for the size
• Ratios 1:1 to 4:1
• 98% efficiency
• Hollow output option (33 & 45 mm)
Miniature applications
The miniature VP Series is an excellent option for miniature automation applications, such as medical and semiconductor, when high performance is required and space is at a premium. The housings are manufactured from high-strength aluminum for a gearbox that is light weight, dissipates heat efficiently, and resists corrosion.
Additional information on the Gam VP Miniature Spiral Bevel Gearboxes can be found at-
https://www.electromate.com/assets/catalog-library/pdfs/gam/Gam_Spiral_Bevel_Gearboxes_catalog.pdf
Filed Under: Gears • gearheads • speed reducers, Motion Control Tips
