Planetary gear bearings from CCTY bearings
By Mike Santora | June 26, 2018
CCTY-RNN-Bearing-imageAfter two years in development and extensive testing, CCTY Bearing is unveiling its newest bearing series, the RN and RNN full complement cylindrical roller bearings. Planetary gears require immense power to move heavy equipment while operating within a compact design. This series from CCTY Bearing needs only a small amount of radial space and provides heavy load capacity.
Low friction, long life and high reliability are necessary bearing attributes for industrial gearboxes performing under dynamic and static loads that can reach their physical limits. The RN and RNN series meet performance requirements and feature:
  • Low noise and vibration
  • Compact design
  • Precision grinding and super finish
  • Uniform contact stress from an optimized crown profile on raceways and rolling elements
  • RNN guide ring availability
  • Surface treatment options to improve life, durability and speed
Optional features include guide ring, flange and surface treatments to improve durability, life and speed. The cage-less design is ideally suited for planetary gears in:
  • Material handling
  • Construction and agriculture equipment
  • Mining and heavy trucks
  • Wind energy
CCTY Bearing
www.cctybearing.com
Filed Under: Bearings
Tagged With: ccty
