RUWH’s 68 Series deep groove ball bearings feature a steel plate dust cover or rubber seal filled with the right amount of grease in advance. These bearings are suitable for high-speed rotation and require low noise and low vibration. The simple configuration provides high speed, less coefficient of friction, and less vibration and noise. These bearings primarily take the radial load as well as moderate axial load.
Ningbo Renhe Machinery Bearing Co., Ltd. is located on the South Bank of the longest Hangzhou Bay Cross Sea Bridge in the world. “China bearing town,” which is 6 kilometers away from the export of Shenyang Haikou high-speed nunnery, covers an area of 55000 square meters. The factory area is 35000 square meters, with total assets of 1 billion yuan and 400 employees.
Ningbo Renhe Machinery is a specialty manufacturer of mini and medium-size, low noise, deep groove ball bearings in a pore size range of φ5-50 mm in six grades of 0,2,3,8,9 and 16 series. Ningbo Renhe Machinery has an annual production capability of over 50 million sets of various bearings and a wide application level of P5 and P6 under the registered trademarks”RUWH.”
RUWH
www.ruwhbearing.com
Filed Under: Bearing Tips
