At this year’s Turbomachinery and Pump Symposia event in Houston, Texas starting September 12, SKF will present a comprehensive range of solutions designed to enhance performance and extend machine service life in the oil and gas sector.
SKF will use the Turbomachinery and Pump Symposia 2016 to demonstrate how to increase efficiency and reliability, while cutting maintenance requirements in the oil and gas sector through the use of its proven technologies and services. Visitors to the event will see how its bearings, seals and condition monitoring innovations have been specially developed to improve the performance and extend the service life of critical assets across the industry.
Among the market leading technologies to feature at the trade show will be SKF’s S2M magnetic bearings and E300V2control cabinet that allows monitoring and servicing in demanding environments, such as in gas compressors, high-speed electric motor drives and ethylene turboexpanders. Also on display will be SKF’s MBScope service software package, which offers in-depth, autonomous monitoring of critical parameters to further optimise magnetic bearing applications.
Meanwhile, SKF’s state of the art Multilog On-Line System IMx-M will be on show to demonstrate its reliability enhancing capabilities for critical offshore machinery. When used with the SKF @ptitude Monitoring Suite software, this powerful yet cost effective condition monitoring system enables end users to maximise the availability of assets and prevent downtime through early fault detection and diagnosis.
SKF will also present a range of sealing solutions from Kaydon Ring and Seal at the trade fair. These include dry gas seals, circumferential barrier seals, oil buffered seals and seal control systems that are proven to boost the resilience of turbomachinery, while minimising downtime in oil and gas applications.
SKF experts will be available in the booth at the Turbomachinery and Pump Symposia, which will take place at the George R Brown Convention Center in Houston, to give comprehensive information and advice on its wide range of solutions.
SKF
www.skf.com
The post SKF to showcase efficiency boosting oil and gas technologies appeared first on Bearing Tips.
Filed Under: Bearing Tips
