Small footprint power supply for single-phase input
By Frank Tobe | May 9, 2014
SolaFor those applications involving large industrial loads using single-phase power, SolaHD has come out with the SDN 40-24-100C, a 40A single-phase power supply. It is also suitable for manufacturers looking to add new equipment to an existing structure with little to no retrofiring required. Such applications include industrial machine controls, DeviceNet™ control, conveying and packaging equipment, material handling and semiconductor fabrication equipment.
This power supply maintains a small, easier to integrate footprint, is efficient, and delivers the same 40A capacity as the largest three-phase model offered by the company. For manufacturers located in facilities with only single-phase power, this means there is no longer a need to let power supply capacity prevent the running of large industrial loads.
Like all SDN-C Series power supplies, the 40A single-phase model features visual diagnostic LEDs to indicate I/O status at a glance. They come equipped with standard screw terminal connections and a rugged, industrial-grade metal outer case that efficiently dissipates heat, and delivers full power in a temperature range from -25°C to +60°C. Their high MTBF translates into superior reliability, longer life and enhanced value to the end-user.
SolaHD
www.solahd.com
Filed Under: Power supplies, MOTION CONTROL
Tagged With: solahd
