    • Subscribe!
Small sensor with six degrees of freedom
By Frank Tobe | March 11, 2016
DTSWhen it comes to measuring high rates of shock and angular velocity for crash, blast and impact testing, the 6DX PRO may fit the need. These sensors come in a shock-hardened enclosure that’s as small as the diameter of a penny. Weighing only 12 g, they terminate to a single triaxial connector.
The six degrees-of-freedom sensor includes three accelerometers (±2,000 or 20,000 g) and three angular rate sensors (±300, 1500, 8K, 18K or 50K deg/sec) in a rugged enclosure that is less than 3⁄4 in3 (19 x 19 x 14.5 mm). Focused on human injury assessment testing, the sensor is shock rated up to 20,000 g and is IP67 rated.
Testing applications include: helmet testing, automotive safety, airplane seats, parachutes, amusement rides and blast testing. The 6DX PRO is delivered calibrated with pigtail or adapter cables to support a variety of termination options. It’s repairable if damaged and meets NHTSA, FAA, ISO 6487 and SAE J211 data acquisition requirements.
DTS
www.dtsweb.com
Filed Under: TECHNOLOGIES + PRODUCTS, Connectors (electrical) • crimp technologies, Sensors (position + other)
Tagged With: dts
Product Image of the NTE2620
Acromag expands its line of ethernet remote I/O modules
Beckhoff’s EPX series EtherCAT I/Os provide intrinsic safety in IP67 form factors
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
Southco introduces stylish corrosion-resistant stainless steel positioning hinge
    • Subscribe!
