The new STM32F030 Value Line is based on the ARM Cortex-M0 core running at 48MHz. Central to ST’s new Value Line concept is a strong base specification that effectively streamlines component selection and product differentiation. The STM32F030 line of products begins at 16KByte Flash and 4KByte RAM in a 20 pin package, and comprises a total of five parts up to 64KByte Flash, 8KByte RAM and 32, 48 or 64 pin packages. All variants feature a 12-bit 1Msample/s ADC, 1.2V internal reference, communication peripherals, temperature sensor and timers capable of supporting ADC synchronization, dead-time management, and PWM (Pulse-Width Modulation) timing for motor control. In addition to 48MHz core frequency, these rich peripherals set the STM32F030 Value Line apart from other entry-level 32-bit families. An internal RTC and 5-channel Direct Memory Access (DMA), also helps ease application development and improve performance. Moreover, developers gain entry to ST’s full portfolio of ARM Cortex-M microcontrollers, which includes more than 360 variants leveraging extensive pin, software and peripherals compatibility between Cortex-M0, M3 and M4 families.
STMicroelectronics
www.st.com.
The post STM32 Value-Line Microcontrollers Delivering 32 bits appeared first on Micro Controller Tips.
Filed Under: MOTION CONTROL, Microcontroller Tips
