  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Swiss precision motors handle valuable Mars soil samples
By Danielle Collins | February 18, 2021
Was there once life on Mars?
This is the question that one of the most complex robotic systems ever built by humankind has set out to answer. Several of maxon’s electric drives are used for handling the soil samples — and to control the first Mars helicopter.
The rover named Perseverance entered the atmosphere of the Red Planet on February 18, after traveling a distance of more than 470 million km.
Perseverance landed in the Jezero Crater, which was once filled with water, to search for traces of earlier life. The rover looks a lot like its predecessor, Curiosity, but is equipped with more sophisticated measuring instruments and systems. One of its tasks will be to take up to 30 soil samples, place each of these in separate containers, seal them, and place them on the surface of Mars for retrieval and return to Earth by later missions in which maxon will also be involved. This “Mars Sample Return” project is by far the most complex series of missions in the history of unmanned space exploration.
NASA’s Jet Propulsion Laboratory (JPL) is responsible for Perseverance and is counting on technology from maxon to handle the samples. There are ten electric drives in the rover. These are responsible for moving the robotic arm that navigates the samples from one station to the next. Additionally, the motors are used for sealing the containers and placing them on the surface of Mars.
The robotic arm moves the soil samples to the volume assessment and scanning stations, then to the sealing station, and finally into temporary storage — all autonomously.
Image credit: NASA/JPL-Caltech
Drives responsible for mission-critical tasks
Just like the more than 100 existing maxon drives that have been reliably performing their duties on Mars, the motors for Perseverance are based on standard catalog products: specifically, nine brushless DC motors, the EC 32 flat and one of the EC 20 flat motors combined with a GP 22 UP planetary gearhead.
The engineers at maxon closely collaborated with the specialists at JPL for several years to modify and extensively test the drives. The robotic arm on which the BLDC motors are mounted as well as the gripper are critical to the application and the success of the mission.
maxon motors
Left: The modified EC 32 flat drive. Nine of these drives are used in the Perseverance rover. Center: The EC 20 flat with GP 22 UP gearhead. Right: DCX 10 motors move the swashplate, which in turn controls the tilt of the rotor blades of the Mars helicopter.
Image credit: maxon
maxon is also on board the first Mars helicopter
A drone helicopter called Ingenuity is attached to the underside of the rover. Ingenuity is destined to perform the first ever flights on Mars in the history of space exploration. It is solar powered and weighs only 1.8 kg. Six brushed maxon DCX motors with a diameter of 10 mm control the tilt of the rotor blades, which determines the direction of flight. The drives feature high energy efficiency, are dynamic and very light. “In the development phase, we performed extensive tests to make sure that the motors will work as intended under the extreme conditions on Mars,” says Florbela Costa, project manager for this helicopter at maxon.
The Perseverance rover and the Mars helicopter Ingenuity.
With this experiment, NASA wants to test the concept for future drone flights. Flying on Mars is a challenge. The atmosphere is extremely thin, roughly comparable to the conditions on Earth at an altitude of 30 km. The first drone flights are scheduled for May, 2021.
Space applications only constitute a small portion of maxon’s orders, but the high requirements push maxon to the next level. This is evident in the increased quality standards, as well as new testing methods and processes, which in turn also benefit customers in other areas, such as medical technology. “Apart from this, such space missions are simply incredibly fascinating,” says Eugen Elmiger, CEO of the maxon Group. “Time and time again, I feel honored and proud that our drives are used in these technically groundbreaking Mars missions.”
maxon
MOTION DESIGN GUIDES
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
  • 4 Key Trends in Machine Engineering
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
