    • Subscribe!
Wiegand wire energy harvesting components
By Mike Santora | July 18, 2019
POSITAL-Wiegand-Sensoren-590POSITAL’s Wiegand assemblies offer a compact and efficient way of harvesting power for electronic circuits in electromechanical devices, eliminating the need for backup batteries.
The operating principle of POSITAL’s Wiegand modules is simple. A “Wiegand wire” is a short length of specially prepared Vicalloy (vanadium-iron-cobalt) wire. When exposed to a changing external magnetic field (e.g. a nearby permanent magnet mounted on a rotating shaft) the Wiegand wire will initially retain its original magnetic polarity, and then abruptly ‘flip’ its polarity when the change to the external magnetic field reaches a certain threshold. This sudden change in the magnetic state of the core induces a current pulse in a copper coil wound around the Vicalloy core. This current pulse is very short-lived, but the energy harvested from the mechanical movement of the magnet can be captured and used to activate a low-power electronic circuit. An important feature of the Wiegand effect is that the amount of electric power generated with each reversal of the magnetic polarization is constant and completely independent of the rate of change of the external magnetic field, even if this happens very slowly. POSITAL Wiegand modules have been used to reliably power rotation counters in tens of millions of devices, including multi-turn rotary encoders, gas and water meters.
Production Since 1974 – Started by John R. Wiegand
Proven In Encoders & Water Meters Since > 10 Years
Used In Access Cards For > 30 Years
Power Supply For Future IoT Applications
High Energy Output of ~170 nJ
Wiegand assemblies are a core component in POSITAL’s IXARC multiturn absolute rotary encoders, providing a maintenance-free method for powering the counter that records the number of complete rotations that the device experiences. POSITAL also offers Wigand assemblies to other manufacturers. These consist of a 15mm length of Wiegand wire surrounded by a copper coil, all contained in an SMD-mountable plastic structure. Wiegand wire production is carried out at locations in the U.S. and Europe, ensuring a stable, reliable supply chain. These assemblies can be used wherever low-cost, zero-maintenance, battery-free energy harvesting systems are needed to energize electronic counters and other low-power electronic devices.
Posital
www.posital.com
Filed Under: Sensor Tips, Encoders (rotary) + resolvers, Energy management + harvesting
Tagged With: positalfraba
LPPS-36B Series Linear Potentiometer Position Sensor with Rod Ends
Hybrid sensors for connected vehicles
How are wearable systems improving?
Faster than any other IDS industrial camera: uEye Warp10 with 10GigE
    • Subscribe!
