Analyze motion performance easily
The IL5 High-Speed Camera lets you record any gears, motors, machinery, mechanical or robotic equipment that is moving too quickly to process with the naked eye. By using slow motion replay, you can see what you have been missing with normal speed video and analyze the performance of your equipment to improve design.
With recording speeds of over 630 frames per second at HD 1080p resolution, over 3200 fps at VGA resolution and more than 29,000 fps at smaller resolutions, the IL5 lets you see what you have been missing with normal speed video. It saves images to an SSD or SD card while recording high-speed bursts of hundreds or even thousands of images at a time.
Built for flexibility and ease of use, the IL5 camera can be controlled over Gigabit Ethernet with Fastec FasMotion software on a PC/Mac or with the built-in web interface with a web browser on a PC, Mac, tablet, or smartphone. Using the (LR) FasCorder Mode, operate the camera as a regular camcorder to record and pause as needed and follow the action, stop recording and review what you have, and then append additional footage at will, even after a power cycle. The IL5’s Long-Record (LR) option can record at high speed for many minutes at high resolutions, to many hours at reduced resolutions. On-board SSDs are available in sizes from 256GB to 2TB.
Fastec Imaging
fastecimaging.com
Speak Your Mind
