Cicoil provides Crystal-Clear Jacketed Cables which allow for quick, easy and safe inspection of cables in just about any application. Unlike industry standard cables infused with color additives and possible contaminants, the Cicoil Flexx-Sil™ rubber design offers complete transparency, so you won’t need to be concerned about “what’s under the hood / cable jacket”.
Due to the uniqueness of its translucent outer jacket, Cicoil’s Flexx-Sil™ cables also include the following benefits: Confirmation of Design Continuity, Ease of Troubleshooting for Wire & Shield Breakage, Simplified Termination of Parallel Wires to Connectors and Streamlined Circuit Tracing.
Cicoil’s patented computer-controlled extrusion process allows each individual component to be placed in a flat parallel Crystal-Clear profile, precisely controlling the spacing of each individual component, insulation thickness and the overall cable shape. This ensures that each of the shielded or unshielded conductors do not rub against each other or experience failure during operation.
The tear resistant Flexx-Sil™ jacket is also self-healing from small punctures and will not wear, crack or deform due to long term exposure to continuous flexing, severe impact, water, abrasion, ice, steam, sunlight, humidity, flames, ozone, UV light, autoclave, expanded temperatures (-65 °C to +260 °C), vibration, mechanical stress and many chemicals.
Standard “off the shelf” Cables are available for immediate delivery and cable assemblies, complete with connectors are offered in 3 foot, 6 foot and 12 foot lengths. Custom designs, including assemblies with connectors of your choice, 100% tested and inspected, are also available with minimum lead times. In addition, Cicoil offers anti-friction coatings and custom shape designs by request.
Cicoil’s Crystal-Clear Jacketed Cables are Halogen-Free, UL Recognized, CE Conforming, RoHS & REACH Compliant, and are cured continuously, with no debris or material impurities, in an automated, climate controlled environment. In addition, these non-shedding cables are 100% contaminant-free, Class 1 Clean Room Rated and exceed the outgassing requirements of ASTM E-595.
Cicoil
www.cicoil.com
The post Crystal-Clear Cables Offer Complete Design Transparency appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
