With the double-acting piston drive, the parallel and three-point gripper delivers maximum repetition accuracy and stable kinematics. For flexible mounting, Festo also offers a vast array of mounting options in the form of fitting, threaded and centering holes.
Featuring light weight aluminum housing, the parallel and three-point DHxS grippers are also equipped with an integrated receiving hole for the pneumatic piston. The force produced by the linear motion is transferred to the low-backlash gripper jaws through lever kinematics. This eliminates the need for separate synchronization, since the lever is in mesh indirectly with the two gripper jaws through a piston rod.
Meanwhile, the pneumatic pistons of the radial and angle grippers act on the gripper jaws, which are mounted on the gripper jaw guide’s pivot, via a slotted guide system. Much like with the parallel and three-point grippers, this also implies that there is no need for added synchronization.
Pneumatic Tips
Festo’s DHxS pneumatic grippers set new industry standard
Pneumatic Tips
