High Voltage DC Inputs… As Easy as 1, 2, 3!
Pico Electronics has now expanded its product offerings to accommodate the high input voltages required from battery, solar and alternate voltage sources from 100 VDC to 1,200 VDC. These modules simplify requirements from these high voltages to board level requirements from 5 VDC to 300 VDC isolated outputs in one simple step.
The DC1 series have input voltage ranges of 120 to 370 VDC up to 300 watts,
with output voltages from 5 VDC to 300 VDC.
The DC2a series have input voltage ranges of 350 to 700 VDC up to 300 watts,
The DC2b series have input voltage ranges of 700-1200 VDC up to 300 watts,
The DC3 series have input voltage ranges of 300 to 900 VDC up to 50 watts, with output voltages from 3.3 VDC to 300 VDC. Dual outputs and terminal strip models are available.
All models are fully encapsulated and are available with expanded operating temperatures of -40 to +85 C and with selected Mil Std 883 screening for those critical applications where required.
These modules join our 3,000 strong standard products that offer output voltages from 3.3 VDC to 10,000 VDC in a variety of power ratings, regulated and programmable outputs.
Pico Electronics
www.picoelectronics.com
Speak Your Mind
